Hi.
Please forgive me if my first post does not make too much sense since English is not my mother language.
I am from Greece and i have a question that is turbo related as it is certain that nearly if not all of you are more experienced than me.
Having read almost the entire board there is still something hazy in my mind about controlling fuel on a turbo bike.
My bike is a gen1 2007 in superb condition and after much consideration i decided to fit a turbo stage 1 set at 4-5 psi boost max.
My question is this:
Can a power commander V control the fuel delivery using it's 0-5v input from the MAP sensor or i need an FMU?
I think the stock fuel pump is good enough for ~200hp and so is the absolutely stock engine (That's the maximum i will ever want)
In my not so clear mind i am thinking that a pcv with auto tune and lcd screen coupled with a stage 1 turbo set at maximum 4 psi of boost might be a viable solution,
what do you all think?
My intention is to install the turbo my self as i don't want nobody else to touch my bike (for the installation) and then drive the bike under it's own power
to a dyno for further tuning.
Thank you in advance for your time guys.
Chris
Chris
