iomdazzer
hi every one at .org, please can somebody give me solid advice, i have 2000 busa,8900 miles, which i ran factory stock for a year, then decided to put a full system on and its all gone wrong from their, the system i bought is a micron 4 into 1, stock air filter, g pak, and had the ecu remaped with the protech system, similar to the yoshie box, the bike is down on power as what i expected 149.08 rwhp and max torque is 94.88, plus ive got a real bad flat spot at aprox 3200 rpm, which gives a load crack as you roll through given revs, the tuner recons the problem lie s on the intake side, would a power commader 3 usb and a k&n filter sort this out, or am chucking good money at it and getting same result, have attached dyno result to show my problem, my head is now done in, lol, meny thanks in advance DAZZ.....
