New to the forum and new to Busa's. Just brought home an extremely clean '99 with about 3600 miles, all stock. Battery is good and the bike starts, idles and runs fine but..... As you are riding along, occasionally the engine just dies. Sometimes it will restart after a few seconds on its own, and sometimes I need to actually turn the key off and on and it will restart once the dash turn on sequence is complete. Sometimes after a sustained freeway speed run, it will stall as I downshift coming to a stop. When it does cut out, no dash reset, no error lights/codes that I've noticed. I have no service history and have yet to clean/change the fuel filter or check the fuel pump, etc. I've spent a good bit of time searching the forum for similar issues but none seem to be quite the same. I've got no surging or stumbling off idle or at any particular RPM range. Bike idles fine at 1200-1500 rpm (I turned up the idle to 1500 RPM to see if it would stop the problem). Fresh gas. Side stand switch seems to work properly. Any thoughts? Trying to narrow the direction of my search.
Thanks from a new member,
Chuck S.
Chuck S.
