New Chain, need help
Devildust
Not sure if I did something wrong or what but it looks off. Adjusted the slack to proper tension and the adjuster seems really really far back.
Its a DID 112 link chain, stock sprockets size.
13898587420_0ac7422a88_c.jpg20140501_193409 by antonzavalko, on Flickr
I just did mine. Had to remove a couple of links before installing the master link. I'd have liked to remove 1 more but the chain would have been just a hair too short to get the link in. Mine need up pretty close to where yours is so you should be ok. It will take a long time to stretch to the limit.
That looks identical to the position my chain adjuster is in right now with a new chain.
The chain will be worn out long before you run out of adjustment.
From what I found on here its 112, and thats what this one is. Just seems like it should start out shorter, but if that what it is then Im good.
i need one too thats why i was asking about what the stock links on a g1 are. my chain is at the last notch so i know i need one
