neep help identifying a sensor please
mustangracer42
Fellas, I need some help identifying what a particular sensor is. It's on the left side of my 2000 busa as you sit on the bike. It's under the tank and mounted to the frame near a bunch of vacuum lines. It has three wires coming into it. One is red, 1 is green w/ white stripe and the other looks black and "might" have an orange stripe. The denso numbers on the top are 81A0 0079800-4990 5V. It has what looks like a vacuum nipple sticking out the bottom but I can't find a loose vacuum line anywhere near it. Is it supposed to have something hooked to it.
Thanks for helping a noobie out.
Jeremy
sounds like the atmospheric pressure sensor... and no the nipple doesn't have anything attached to it... the hole in the sensor is open to outside air pressure
