i did not see the answer, I have all plastics done and mounted fine. The plug in for the gauges is different and i just did not know if i got a genII headlight harness is all i will need or do i have to do more? thanks
Do you still have the gen1 cluster for the bike?
Your best bet is to notch and modify the gen 2 dash fairings you have and run the gen 1 cluster in place of what would be the gen 2 cluster on a gen 2 bike.
Without a gen 2 ecm, which then leads into engine parts and such you will be hard pressed to make a gen 2 cluster work if you could even do it at all.
