Need PCIII Map for my Hayabusa
Boyer
I have made the following modifications to my 2006 Hayabusa and was wondering if anyone had a good map that I could use since I live far from a dyno center. I have replaced my exhaust with a full 4:2:1 K&R exhaust. I have done the small airbox modification. I have removed the pair valve. I have installed a TRE and gear indicator. I changed the air filter to the BM system. Finally, I installed iradium spark plugs. Is there a map out there that will help the bike run better?
MikeSomething
The only real factors are the single exhaust, air filter, and sm airbox MOD.
If I was you, I'd go onto the power commander website and try any of the maps for a single exhaust w/ an aftermarket airfilter and take it from there man.
Boyer
Thanks, i am looking into using map 007 that i think takes the most factors into accound. Appreciate the help
B@DA$$08BUS@
Keep in mind, those will only get you close. The best bet is to see a tuner for a custom tune. I know you know all this, just saying.
