I am trying to raise my rear back to stock height. I have aftermarket links that has 3 holes in the lower link. I understand the upper most, or shorter length will raise the bike. However, here is my problem. The link is hitting the braket that holds the belly wing and the aluminum sub frame that the belly wing is bolted to. So, what do I do now, I dont have time to get original links. Do I A) Put it back like I found it? B) Grind the end of the link about a quarter so it does not contact the bracket?
In making what I have work, I am not sure that a contact with the link will be a good deal. It looks as if this part of the suspension has a pivot point and I dont want anything to bind. Help so I can get Sally back together!
