Need info on 2 intake cams for turbo
Whiteghost377
Im looking for anny info on the 2 intakes set up my motor has the 2 cams i dident check when i pulled motor apart and not sure what to do the cams are spot weilded and a bunch of marks on the end.allso im useing stock 81 mm new turbo pistons 8 7.1 replaceing stock pistons and the motor had a 80 thou plate do i still need to use the plate with the low compression pistons . If i dont use now my cam time is gunna need degreed thanks anny info will help
Whiteghost377
Not to sure i guess if Certin degrees are used im new to the busa motors my cams look like i can see the stock marks and its about 5 links from stock ya im not realy sure what to ask that will help me not crush valves i cant move the ape ajust sprockets thair weilded
Mr Brown
I'm not trying to sound like an ass, but if you don't know how to degree your cams, take it to someone who does. I may be wrong, but it seems like you're in over your head. Cams need to be degreed if you're using a spacer plate to lower static compression. Eliminating the spacer plate would presumably require redegreeing them.
moko
It sounds like someone before redegreed them with extra marks... You could at least check your 1 piston.... Make sure it's top dead center... Then see if new timing marks on plate is lining up with factory mark
ali123
Banned
With all due respect, this bike/build needs to go to a reputable shop. The questions the OP is asking shows that he has done minimal to no research, and we all know how this is going to turn out . . .
lol... u know whats scrary… he is in wappingers falls,NY… thats exactly the town im in.... OP... if ure reading this... PM me... I got a mild turbo bike.
Big Pk
Just not to create a neq thread, have you tested two inlet cams on your turbo? Will this add any power output? Some are claiming an increase abt 20-30hp..
105/105
Any input will assist
POWERHOUSE
Frank
Intake and exhaust cams are NOT the same, and I am not talking about lift. The lobes on the cams are spaced apart differently. Cam lobes are designed to contact the valve buckets dead center; when you put
another intake cam on the exhaust side, the cam lobes do not run dead center, they run biased towards the
outside of each bucket. Yes, this has been done, and no, it is not going to get you 30 hp, that is BS.
Would I do this to my bike? NO. BTW, the OP of this thread joined this forum 1 month ago, made this
post, and left.
Latest Bikes
Forum statistics
Threads
172,764
Members
47,643
Latest member
BxUxSxA
