ImmortalPMCWG
Вот обновлённый вариант текста для форума, с добавлением про две маленькие клеммы:
Subject: Need full pinout and resistance values for Gear Position Sensor (37730-24F00) – including 2 small terminals
Hi everyone,
I’m working on a faulty Gear Position Sensor for a Suzuki GSX1300R Hayabusa K2 (Part number: 37730-24F00). One of the terminals appears to be damaged, and I’m trying to repair it by checking and replacing the correct resistor.
I found the resistance values for the 6 gears and neutral — they were super helpful, thank you!
6th gear – 15K ohm <br>5th gear – 6.8K ohm <br>4th gear – 2.75K ohm <br>3rd gear – 1.5K ohm <br>2nd gear – 835 ohm <br>1st gear – 588 ohm <br>Neutral – open (infinite resistance)<br>
However, this sensor has 7 large terminals and 2 small ones (as seen in the attached photo), and I couldn’t find any reliable info about what the two small terminals are for, or what resistance/voltage values they should read in each gear or in neutral.
If anyone has a full pinout diagram or knows the function and values of these 2 small terminals — that would be a huge help.
Thanks in advance!
Greetings from Russia
Если хочешь, я могу перевести и на французский или немецкий, если вдруг попадёшь на профильный форум не на английском.
Hi everyone,
Thanks in advance!
