busastrom
Well, I thought this should be a pretty easy task. I had done this with my brakes with no issues.
I made sure the reservoir was full and pulled the clutch, holding, and then opening the bleeder valve. The fluid came out (with no air). I continued this several times. Replaced the fluid in the reservoir with dot 4 synthetic as soon as it got about half empty.
Well, put everything together (with a full reservoir) and now it is shifting harder than before. Going from neutral to first gives a really bad jolt. Going between any other gears is harder than normal as well.
I figured there was probably an air pocket in there so I tried the procedure again (with no air showing up in the line) but still no good.
Anyone have an idea where I screwed up and how to fix?
Thanks guys.
Thanks guys.
