05turbobusa
I just traded for my first busa (2005), and the guy I got it from had it sitting in the garage for like a year. The bike only has 995 miles on it. The clutch will not engage unless you pump it a few times then it works like normal. I figured it had air in the line so I attemted to bleed the air. I tried every way i know including using a mity vac...... Now when I pull the clutch it engages fine, but when I put it in gear and go to let out on the clutch it just jumps and dies when I let it out about half a inch. I took the master cyl. cap off and tried the clutch. When I let out on it, it squirts fluid out when I let out about half an inch. (the same place it jumps and dies) So im guessing the fluid is by-passing something.
Is the master cyl. bad?
If so do you know where I can get a re-build kit?
Any help would be greatly appriciated!
Thanks, Dustin
Thanks, Dustin
