Hi.
I have now reached a point where no one (including all professionals near me) here can help me solve the fuelling problem that i am facing so i will post my problem here in case anyone has ANY idea.
My bike is a gen1 with mcx400 turbo + liquid intercooler plenum running at 12-13 psi which produces 270 hp with a silent full exhaust system.
The fuelling system uses the gen1 ECU along with a split second box in order to control the 4 secondary injectors mounted on the plenum,
a Malpassi 1:1 FPR, a Bosch 044 inline fuel pump and the Honda Firebird injectors.
Everything was working well until one day the bike could not get past 7000 rpm with my AEM failsafe gauge showing an AFR of 18:1 or more.
Back to the tuner where the split second box was tested and found ok, ALL injectors where cleaned at a specialist's shop, FPR was leaky and it was replaced with an Aeromotive 13129 and the 044 fuel pump with the newest Bosch version which is smaller and completely silent.
After a completely new tune the bike made 284 hp and the AFR was spot on except at low rpm (1200 to 4000) where it reaches 10 to 11:1.
My tuner told me that he couldn't make it any leaner than 11:1 something that i don't understand at all since my injectors are only rated at 330 ml.
I personally watched the whole tuning process and i am sure that everything else was working fine.
Where is the problem you may ask, well on the road the AFR is completely off reaching 17:1 at 5000 rpm (6th gear) when accelerating and the bike stalls for a second or two at 7000 rpm until it goes past 8000 where it picks up again with AN AFR OF 12 ~12.8 :1
Btw at lower gears those symptoms do appear also but in a more benign form.
Also the AEM failsafe AFR readings are spot on when compared with he dyno's readings and the stall i am feeling is very real so it is not a failing UEGO sensor.
In the 1st photo you can see this while at 4th gear and in the last one while at 6th gear.
Any ideas or mods (new ecu, power commander etc.) welcomed because at this point my tuner says that the bike works fine on the dyno and the street as he also road tested it (i can testify that on the dyno it works like a dream) but for me it runs like crap on the street not to mention that it burns more fuel cruising that going with 120 miles/h.
Thank you all in advance.
Chris
Chris
