Need Help, 2005 Busa shut off 3 times
sccrvettel82
I've been quiet lately...Don't m
2005 Busa with 989 miles. Rode 300 miles yesterday and then another 100 today. While turning around in a parking lot it just shut off on me. This happened twice. Then while I was downshifiting with the clutch in coming to a stop it did it again. The gauges and lights were still on but the motor just shut off. Hit the starter button and fired right back to life with no problems. Is this a common problem? I checked all three times and kickstand was up all the way. Any suggestions?
does it always occur when shifting?
maybe there's a short at the clutch lever position switch... or maybe the side-stand switch?
I had this happen a couple of times on my 04. Most likely due to the idle being too low. Set it to around 1100-1200 and your problems should go away, as mine did.
Thanks a lot guys. i will give it a try and let you know how it works out.
