Need a Speed Rotor for Gen2
kevin8105
Hey guys, I am in desperate need of a rotor for speed sensor on my '08. Part number 34981-47H01 . It is the 4 bladed rotor that goes on the front sprocket. No one I have talked to has them in stock and has to order them from manufacturer.
If anyone has one i would be more than happy to buy it from you!
I have 3 gen1's but they are different.
Any local Suzuki shop would be the quickest, but Justin will be cheaper!
what happened to yours??
I broke that thing, thats what happened! :laugh:
First time changing out sprocket and got a little hasty. didnt realize that it needed to come off before the nut holding on the sprocket. Hit the sprocket nut with an impact wrench and sheered off the outside flange of it.
If they are grind off the flange and it will work
They are all still there, the flange is really just there to keep the nut from backing off the sprocket, right? Wondering if I should just put a washer behind the rotor to achieve the same effect until I can get a new one.
The flange has nothing to do with holding the sprocket on, grind it off and it should work fine!
