I determined it had a rod knock and tore down the engine. I found a set of rods and a crank. It has a full Yosh exhaust and Yosh cams. It appears to have been running rich or maybe it needs valve seals...I will probably just replace the seals since it's apart.
I think that I should probably upgrade the ECU to a '02 so that I can run Boost by Smith. I don't have access to a Dyno up here and it sounds like this would be the way to go.
I'm confused about how to determine what color bearings to use? Do I measure the journal to figure it? Then use plastigage to make sure it has the right clearance? Not sure where to start?
