goodluck boosted finally Donating Member Registered Apr 18, 2009 #1 just trying to finish with the plastic grinding to make it fit right and take it to johnny cheese next weekend to get a tune on
NINJA KILLER JUST CRUISN ' Donating Member Registered Apr 18, 2009 #5 That's gonna be one fast Busa Eric !!!!
goodluck boosted finally Donating Member Registered Apr 18, 2009 #9 DropBusa said: What, no engine work shots ?? Click to expand... here you go
goodluck boosted finally Donating Member Registered Apr 18, 2009 #10 its just a hahn stage 1 nothing else done i already had alot of other things done like clutch springs and high volume oil pump gear
DropBusa Registered Apr 18, 2009 #11 O..... i meant engine. I thought it was a stage 2. my bad. What fuel filter did you use on that setup?
dadofthree Seasoned Beef Donating Member Registered Apr 18, 2009 #13 Very nice, never saw a dump pipe cut that short. Just a stage 1
goodluck boosted finally Donating Member Registered Apr 18, 2009 #14 DropBusa said: What made you go with the oil pump gear ? Click to expand... well more oil pressure just a good mod to do from what i have read
goodluck boosted finally Donating Member Registered Apr 18, 2009 #15 DropBusa said: O..... i meant engine. I thought it was a stage 2. my bad. What fuel filter did you use on that setup? Click to expand... just uses a standard ac delco filter so they are readily available at any parts house nothing special
macon454 181.552 mph Texas mile on a B-King 3/28/09, AKA "C Donating Member Registered Apr 18, 2009 #18
