Low rpm Jumpy jerky touchy throttle
Neco
My 08 hayabusa was jumpy at 2500-4000 rpm, after swapping all the sensors like tps, map.... and ecu swap ecu remapping nothing changed, it was end up being crank shaft positioning sensor on flywheel, swapped that with new generator and everything was fine, i would like to share my experience, hope it may help.
Kiwi Rider
So how did you eventually find that it was this burnt out stator was the cause of the problem?
The battery must have been quite low in it's charge state and cranking speed slow and hard to start the bike? Jumper leads necessary?
Did you fit a genuine Suzuki stator (generator) or a cheap chinese part?
Neco
Generator was fine all electric system was fine, but sensor was the problem i just change the hole thing, i find out after hours of work and trying the swap other things, i was lucky to have great mechanic, i used original suzuki part
Kiwi Rider
Wow, being so black it looks burnt to me. . . so its still charging OK? Amazing. I guess it must be just black from having really dirty oil in the engine . . change your oil more often lol. :poke:
Neco
I’ve just bought the bike like that, they didnt take care of it, for sure ill do my best
Kiwi Rider
Kiwi,
You might want to go over and have a look at the "trump impeachment" thread. You will see that you cant use that kind of language here. SO please behave.... :poke:
And here I was thinking we had freedom of speech . . . I'm gonna have to choose my words carefully from now on,
and as for that sh*t storm you created with the Trump impeachment thread, I'm keeping right away from that,
politics and religion is the reason people fight.
Oh, apart from money. Oh, and sex.
Anyway, I'm here for the brotherhood of the mighty Hayabusa Family!!
Sandow
you hopefully know i was kidding, right? ;)
Neco
Here is what i have checked or changed before i came to crank shaft sensor i dont want you to jump to conclusion on csp sensor if you have jumpy throttle you may have something else wrong
Tps sensor
Map sensor
Ecu
Ecu remapping
Air intake pressure sensor
Cam shaft positioning sensor
Ignition coils
Spark plugs
Fuel enjectors
Fuel pump pressure
Battery
Cylinder compressions
Timing
Intake necks (i dont know the name those plastic things within intake assmbly and head 4 of them, actuly they were faulty and leaking air also)
Finally tried crank shaft sensor and turned to be the problem, those thing were all done on dyno
Berlin Germany
thanks a lot for this hint when jerking at constant speed
this prob we hadn´t have here till today - so i learned again something new
thanks again for "teaching" :thumbsup:
i´ll take this hint as pt. 6 to my homepage´s list
but if you have that jerking at constant speed
there might be some other probs like :
1. throttle cable too tight - no 3-5 mm gap at throttle grip
2. at ´99 & ´00 busa - old ´99 kinked fuel hoses - see at ´00 update manual part 4 - use ´00 hoses
3. shrinked shock absorbers in rear wheel for sprocket drum - change to new
4. gear sensor fails (it is "sitting" behind outer clutch drum) - replace by gen II´s
5. again ´99 & ´00 busa - external pump - pumps´ filter "jammed / blocked" and fuel pressure failing - my exp. was to change to internal pump - but VERY tricky & quite technically complex and expensive
Thread starter Similar threads Forum Replies Date
J Low rpm power loss & top speed way down Busa problems 44
H 03 40th low RPM misfire Busa problems 6
H How low can your RPM's go in 3rd gear General Bike Related Topics 6
Andrej Gen 1 - Low rpm poor running Busa problems 2
G Dying At Low Rpm Busa problems 7
J Hayabusa Misfire At Low Rpm Busa problems 16
P Misfire below 4.5k rpm after low fuel Busa problems 8
FastCurrey Low RPM misfire Busa problems 6
W 01 Busa code 25 Fault with sluggish miss at low rpm - help! Busa problems 1
T Bit of a chugging at low RPM? Busa problems 9
D 2nd Gear Low RPM Problem General Bike Related Topics 6
E Low Speed RPM Question... New Owners Forum 5
mattd428 missfire at low rpm Busa problems 2
L Hayabusa Sluggish in low rpm range General Bike Related Topics 2
R mis fire at low RPM Busa problems 4
B Low RPM miss... Busa problems 8
A power loss at low rpm Maintenance and Do-It-Yourself 1
M surging at low RPM General Bike Related Topics 17
G More power at low rpm General Bike Related Topics 26
T '99 low rpm miss Busa problems 23
R ANY ONE HAVE A LOW RPM STUMBLE? Busa Mods 9
B why is the hayabusa jerky at low rpm? General Bike Related Topics 14
T Coughing/Jerking at low rpm Busa problems 16
R Poor low RPM performance (first post) General Bike Related Topics 23
ottafish Headlight Projector retrofit with swapping Hi>Low and Low>Hi ? Gen II Busa Information 10
N 2006 missing/surging at low throttle Busa problems 3
J How to fix jerky low end throttle Gen II Busa Information 10
S Inconsistent idle and low idle stuttering General Bike Related Topics 37
M Engine in car. Need low fuel light. General Bike Related Topics 1
F suzuki gen2 hayabusa Low Profile Oil Pan Wanted 2
B Low Compression question General Bike Related Topics 12
202mphbusa I just scored a carbon So Low. Tank General Bike Related Topics 16
Rockstarmx11 Best low pro tire Tires 6
B Low profile tank shell mounting Appearance mods 1
Hauie Low miles Gen II Busa Information 32
Zrultima Huge loss of Power and stuttering at low rpms Busa problems 60
Blkoutbusa Gen 2 low beam (HID) shuts off when I flip on high beam Busa problems 5
R Low compressions General Bike Related Topics 15
M Low Beam keeps blowing Busa problems 5
Kiwi Rider Low Mileage Gen 1 for sale General Bike Related Topics 11
S Low Mile, 13 Year Old Bike.....questions General Bike Related Topics 22
Mark61 After 10k Miles, Still Struggling With Low Speed Maneuvers; Please Help! New Owners Forum 72
Mythos How Low Can I Gear And Still Do 200 Mph? Gen II Busa Information 35
B Low Oil Level Gen II Busa Information 13
c10 Low Speed Hayabusa Maneuvers General Bike Related Topics 8
diablo_01 Low Coolant By The Radiator Maintenance and Do-It-Yourself 4
nitrobusa08 Are There Any New Led Low & Hi Beams That Are Better Than Stock Lights ? Electrical Mods 11
229ZUKID Tail End Too Low 1/4 Mile 10
229ZUKID Tail End Too Low Appearance mods 3
B How To Lower A Busa Real Low? Engine and Performance mods 13
Similar threads
Latest Bikes
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
Forum statistics
Threads
174,394
Members
48,397
Latest member
ManiacJack
