jeremy78233
well I finished my install on a used kit with a mitsubishi turbo, looks verny similar to a hahn kit. Running stock injectors with a PCII, bov, external wastegate, fmu. I have a very generic map that is dumping to much fuel and is taking out 5 degrees of timing at 100% throttle. Two runs @ 190hp, 121 ft.lbs., a\f was 17.5 (super rich). From idle to WOT the bike is rich, FMU is set a 40psi and spikes to around 90+. Any one have a good turbo map for 6lbs and a similar setup? Very dissapointed with 190hp was hoping for low 200's, please any help would be most appriciated. Also my boost guage is hooked up to three of the throttle bodies and the needle shakes vilently not smooth any way to fix that?
