i just want to know if i will be able to adjust pegs down abd back , with an hmf highmount system installed , the pipes look real close to the stock rearsets , and realy dont want to spend the $$$ for linited adjustment ?
Im getting the vortex adjustable solid mount peg rearsets. I dont think you can bring them down. Only from stock height you can adjust up and back. Usually the only reason you get rearsets is for track and canyon stuff so you can improve ground clearance when putting a knee down. It also puts you in more of an ergonomic more akin to racing.
Some people have looked into the Buell peg mod. Do a search on this. I think that MAY be what you're looking for. And it'll saved ya $300.
thanks , i would like to increase ground clearance, also i would like some more leg room sliding the pegs back sounds good , but with the hmf highmounts i already have installed the s pipe rises quickly after the rearsets so i am not sure if they will fit , do the aftermarket rearsets take up the stock footprint or are they larger ?
