Runinwithscisrs
I replaced my turn signals on my new 2011 Busa with the 18 LED lights and like everyone else the timing is off. I initially installed the resistor that came with them but the timing wasn't fixed and they just heat up badly. I have seen plenty of threads on here for the first gen Busas and rewiring that you have to do. Not sure if its the same for the Gen II. What im asking for is a replacement module that I can just plug n play with no wiring. Pop out the old and in with the new and be done with it. Has anyone done this with the Gen II? I have seen a few sites with option but not sure what I should be looking for.
Custom LED Electronic LED Flasher Blinker Relay - Plug And Play
LED Turn Signal Flasher Relay GSXR 1300 Busa Hayabusa | eBay
LED Flashers Blinkers Resistors Load Equalizers for Turn Signal Replacement Bulbs Rapid Flashing Fix
I apologize in advance for starting a new thread on this but im just a little confused with the difference of years and im just looking for something simple.
