Thanks for the input everyone. It is the stock undertail with the shovel cut off and sanded smooth. I mounted the plate using 2 pcs. of 1" alum. angle bolted to the insides of the undertail where it comes out at a 90* angle. For the LED I will post back with the model # and where I purchased, for mounting the LED I used one of the stock rear reflector mounts, aligned the light to spot on tag and bolted to the bottom of the u.tail. I will put some better pic's up in a few. The taillight is from ClearAlternatives.com and I love it, especially the integrated turn signals. I did have a problem with the taillight assy....two of the resistors broke loose off the board from the soldering joint but they had rma'd a new one to my door the very next day.
