CPR_MCOCHRAN
I was curious if any of you guys ever had a issue similar to mine. I'm still getting the kinks out of my turbo install and i thought i would post this one because its got me scratching my head. The dyno tuner left me pretty rich to be on the safe side. Normally at idle it running between 10.0 and 11, then under throttle and boost it runs at about 12.5 to 13. Everything was going good until i made a interstate run and hit the boost a couple times. During the runs it was fine running the normal 12.5 to 13, then after letting it decelarate and getting off on a exit ramp, I down shifted and came to a stop. I watched it start leaning out as i was coming to a stop and it went all the way up to 16 when i got stopped and it was wanting to cut off. Giving it a little throttle it would bounce around 14 until i was coming to a stop. I switched off the ignition, turned it back on and it was back to the normal rich 10 to 11 again. It ran fine again until the next interstate run to see if i could reproduce the issue and it did it right on queue. A quick reset of the ignition and it was back to rich side and ran fine all the way home. I have no clues on this one. I do have s2000 36lb injectors on it, which i know is over kill for the velocity stage 1, but i figured that would keep it rich if nothing else. Fuel pressure at idle is only about 20 lbs, but as soon as you touch the throttle it jumps to 40 and then pegs it at 120 under boost. Any ideas?
