#becauseracebike
So just hooked up an MSD Launch master bike is stock motor with a Murray Pipe, PCV, and a Schnitz Racing ECU flash. Issue i'm having is the bike starts fine and the Launch Master powers on but when i run the blue wire up to the Black/Yellow wire I can't seem to get it to work. Now i'm just trying to test is yet so the airbox isn't on the bike yet i don't want to put it all together and now have it work. My main question is just for testing purposes i just stuck the wire in the back of the black and yellow connector to make sure its right. Does it matter if i test is right at the clutch lever or do i have to splice in and try it after it comes back out of the housing and in to the wiring harness? I did some searching and saw that someone used the black and yellow wire but it doesn't seem to work for me. Bike is a 2008
