would the Kick Stand sensor effect the computer to throw FI codes?
my bike showed all 4 injector codes.
as posted in another thread my bike hits a wall, FI light blinks, then a short while later shuts down. when i go to restart it takes a few tries. i noticed when i move/activate the kickstand/sensor the bike starts up. then it starts all over again.
i noticed there is no code for the kick stand sensor on this list.
c00 none
c12 crankshaft positions sensor, pickup coil signal, signal generator
c13 intake air pressure sensor #2, for front cylinder
c14 throttle position sensor
c15 engine coolant temp sensor
c17 intake air pressure sensor #1 for rear cylinder
c21 intake air temp sensor
c23 tip over sensor
c24 ignition signal, coil #1 for rear cylinder
c25 ignition signal, coil #2 for front cylinder
c28 secondary throttle valve actuator
c29 secondary throttle valve position sensor
c31 gear position signal switch
c32 injector signal #1 for rear cylinder
c33 injector signal #2 for front cylinder
c41 fuel pump control system, fuel pump, fuel pump relay
c42 ignition switch signal, anti theft
c44 heated oxygen sensor
c49 pair control solenoid valve
gurus?
c00 none
c23 tip over sensor
gurus?
