I have a Powercommander III USB unit fitted to my K8 Hayabusa. I am having trouble with the software, the issue being calibrating the throttle position. I have checked the engine and loom working specifications as per the Suzuki workshop manual and both throttle position sensors are working normally. When I hook the unit up to my lap top, the software picks up the unit and I can get the map from it and send another map to the unit etc.
With the engine running at idle I reset the throttle position in the software as per the instructions in the Dynojet software manual. On initial start up, with no throttle, engine at idle speed etc, the % Throttle value flickers between 4-20. When the throttle is applied, from nothing to full throttle, the % Throttle registers a max value of around 50-60. At a constant 4000rpm (about 20% throttle position), the % Throttle value is 0. Basically, the % Throttle value doesn't represent the position of the throttle.
With the ignition on but the engine off, I reset the throttle position in the software. The software now registers a % Throttle value that represents throttle position i.e. half throttle gives a % Throttle value of around 50, full throttle gives a % Throttle value of 100. When the engine is then started the values change and go back to the same situation as before i.e. % Throttle values do not represent the throttle position!
Can anyone help? lease:
Thanks in advance
Thanks in advance
