Johnnycheese
1313R
Johnnycheese, Can you hook me up with a map for a 2003 Busa With the Pair removed, PC3R, K&N air filter and a Full Muzzy stainless header and aluminum can? Many Many Thanks.
<!--EDIT|1313R
Reason for Edit: None given...|1072101178 -->
That is a basic Map
If you go under power commander the downloads then suzuki then you will see a map with your exact needs.  Do not  worry about seeing Pair removal.  All you need to worry about is Full system and K&N filter.
a 2003 Busa With the Pair removed, PC3R, K&N air filter and a Full Muzzy stainless header and aluminum cans
http://www.powercommander.com/suppsuzmaps.shtml
Muzzys
<!--EDIT|Ninja Eater
Reason for Edit: None given...|1072053792 -->
The powercommander website maps aren't any good.  PM me your email address and i will send you the 3 differnet maps i have.  I have the same set up except i have a bmc race filter.
<!--EDIT|busabrother
Reason for Edit: None given...|1072054523 -->
WHY?
