I used a normal bike jack with a board across the center so it was balanced and put it on the bracket that goes around the exhaust. The strapped it to the jack. Worked well.
My friend has a jack made by Redline that I have used that works excellent! I used to use a regular jack with a board till the bike fell off the rearstand while changing the front wheel
Reg jack works fine for doing the rear if you have a Baxley
when I installed my 240, I lifted the bike with a swing arm stand, then used a big block of wood under the exhaust y-pipe and lowered it down.Worked fine and was very stable.
