jermzfree
I have an 02 busa w/ 26k on it. I have a rcc stage 1 kit with plans of running 6lbs of boost. Before having the turbo installed I had a dyno to get a baseline hp. It was a little low (139hp). I checked the compression on the cylinders, and they range from 180-182psi. I also ran a leak down test, which showed no sighns of valve or head gasket problems. Should I proceed with the install? or is the turbo going to cause a lot of blow by past the cylinders?
