Either way you will have to start by removing the nose cone (contains both the headlight and ram air tubes).
Once the body work is off, the headlight will go with the nose cone and the ram air tubes stay with the frame.
The ram air tubes then can be removed with one bolt each and slid forward out of the frame. You then can position your LED's drill holes for the wiring and glue everything in place with RTV silicone
The headlight can be removed from the nose cone by unplugging the wiring and removing the 4 bolts around the outside and just pulling the light straight back from the cone. You then have to open the housing (very carefully lest you brake the tabs and be unable to reassemble the light) and you will be good to go installing the halo's.
