I did some searching and couldn't find an answer to my problem....
I installed a welded clutch "hub"/mod and also installed new steels and fibers. I also installed 3 stiffer springs and used 3 of the stockers. I never removed the basket, just the inner hub and nut that holds everything on.
Reassemble everything and start the bike.
Bike starts fine and idles fine, but....
I go to put the bike in gear while running and it literally starts to pull forward with the lever pulled...... Ok......
So I try to put the bike in neutral and it just goes to second. After multiple attempts, all I can get is first and second.
Turn the bike off and goes into neutral no problem. So I put the lever setting at "4"(stock levers), start it and put it in gear, it doesn't pull forward but I can feel the bike wanting to roll. Still can't find neutral with the engine running.
What's going on?
What's going on?
