Inline fuel pump routing
I had to replace the fuel line going from the tank (an6 fitting) to the inline fuel pump under the tank. I am having issues with the new line kinking. The fuel pump takes about a 1/2” hose, so I have to use a reducer fitting to go down to a 3/8’s for the fuel line to the filter then the tank. I need help brainstorming on what to do for this, or if you have suggestions on a better routing idea. I have the fuel pump zip tied where the crank case breather is, so it won’t bounce around like how the previous owner had it setup.
Thank you for your suggestions.
Hi. First what is your fuel pump,filter and fuel line. I would go with AN fittings and get the pump off of the motor.
I wish I could tell you exactly what pump it is, but unfortunately i’m not certain. I purchased the bike how it is and have been trying to fix some issues here and there. The old fuel line going from the tank to the pump was trash on the inside, so o threw it out. Right now I’m just using regular fuel line from Napa. The filter is a small 40 micron filter with an aluminum case that I found online. If you know of a specific fuel filter you can recommend, i’d very much appreciate that.
I’ll try to get a picture tonight when I get home, to give better detail.
Hi. I have an Aeromotive filter I us AN6 lines an Borsch 044 fuel pump That I will put in the tail.
Thread starter Similar threads Forum Replies Date
PADEROLIS Gen 2 Inline Fuel Filter Mod. Gen II Busa Information 3
M fuel line and inline filter Busa problems 1
S inline fuel filter mod Engine and Performance mods 6
S inline fuel filter anyone? Engine and Performance mods 9
B.Eskedal Hayabusa inline Six All Motor 74
B.Eskedal Inline five Hayabusa All Motor 274
T Can I run an inline electric water pump with stock water pump? Modifications & Aftermarket Equipment 5
jaschil69 Resistors go inline? General Bike Related Topics 9
T Gen1 fuel pump. Wanted 4
3WheelerMod Fuel pump not cycling.... Busa problems 5
N 2007 hayabusa fuel gauge the isnt working Busa problems 1
J No fuel Busa problems 23
T Gen 1 CHEC light no fuel prime or start - Fix Busa problems 0
rubbersidedown Fuel filter Turbo 0
rubbersidedown fuel injector cleaning Turbo 7
Kevin Jones My favorite fuel pump grommet, 15114-35F00 Busa problems 0
I i need an intank fuel pump!! General Bike Related Topics 11
I Fuel problem! General Bike Related Topics 19
N Fuel tank has hard greyish bumps all over the inside. General Bike Related Topics 45
mike miller Fuel pressure issue Turbo 5
M 2000 hayabusa fuel pump Busa problems 5
F Fuel pump not pumping Busa problems 9
D External Fuel System Turbo 8
D MAP SENSOR, FUEL REG AND BOOST GAUGE Turbo 2
O Fuel Injector Cleaning Services Maintenance and Do-It-Yourself 2
G 2001 busa fuel pump General Bike Related Topics 2
B 2000 busa fuel problem General Bike Related Topics 3
Scooby315 Fuel Pump Painted Busa problems 9
J No power to fuel pump General Bike Related Topics 16
rubbersidedown Thanks to member Zeepopo for this recomendation (fuel additive) Maintenance and Do-It-Yourself 7
B 2010 Busa fuel prime issue.. General Bike Related Topics 5
rubbersidedown Hate to have to go in,but I think,no choice.Fuel injectors. Maintenance and Do-It-Yourself 42
S Gen one fuel pressure General Bike Related Topics 8
K Wanting to buy 99busa but owner said needs fuel pump. Parts and Modifications 36
C aftermarket fuel strainer compatibility Gen II Busa Information 5
c10 Gen 2 Fuel pump sock replacement video . Gen II Busa Information 14
M Engine in car. Need low fuel light. General Bike Related Topics 1
B 2002 fuel tank blue silver Parts and Modifications 4
E 99 hayabusa - What is the part number for the gasket that connects the fuel pump assembly together? General Bike Related Topics 3
D Turbo Fuel System Gen2 Turbo 3
D External Fuel Pressure Regulator Busa Mods 1
SeaMonkey Wanted gen 1 fuel injectors Wanted 0
Sandow Top Fuel Dragster Fuel Pump Demo single cylinder Off Topic 11
M Fuel injectors General Bike Related Topics 8
M HAYABUASA GEN 2 FUEL INJECTORS Gen II Busa Information 1
J Start button does nothing fuel pump not priming General Bike Related Topics 37
J Fuel Tank Sealer Busa problems 10
rubbersidedown Royal Purple fuel additive Random Thoughts 5
K Fuel not reading correct, please guide me General Bike Related Topics 5
Turbo Bob What Heat Resistant Wrap Fuel Lines? Turbo 20
Similar threads
Latest Bikes
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
Forum statistics
Threads
174,390
Members
48,388
Latest member
Jsthom3
