ignition timing for stage 1 kit
Nick Kickass
Hello my busa is an 00' so apparently a later model ecu or an aftermarket module or engine work is required to adjust the ignition timing.
Apparently it will have run somewhat richer if the ignition timing cannot be adjusted.
Is adjusting the ignition timing from stock really beneficial for a stage 1 kit?
less than 10 # I would not worry about it with good fuel
you do have to give more info???
stg 1 what kit
what wastegate
what compression etc etc etc
Its rcc kit, 8 lbs boost, lowered compression (via optional base spacer) with alcohol injection. Running pump gas (93).
With the alcohol injection you don't really have to pull any timing . . . still, it is safer to pull a few degrees and won't really hurt you power-wise . . .:laugh:
