da busa guy
dennis kirk makes an item called an ignition advancer it gives the ability to advance timing up to 4 degrees. since the Busa uses regular fuel, it seems that if you bump timing 4 degrees and use premium fuel,it seems you would get a good performance increase,especially at lower RPM. anyone installed one?
