turbojonny
Do I need this to be active? I switched it off via the ecu. I think it was switched off with the original turbo map. The bike has runnover rich on boost since the rebuilt motor was put in. Perfect until boost, then too rich.
Throws a c40 code when the isc is active (c40 is the isc code). I just dont know if it's relevant to air fuel if it is not being used (sgur off).
