I've just about had it with this brake system. Got the rear & clutch switched to Galfer lines, but I cant for the life of me get all the air bubbles out of the front lines. Been at this project for 5 frickin hours.
My brake bleeder is holding 20 to 35 lbs...only took me 2 1/2 hours to figgure out how to get a seal on the darn thing.
Anyhow, all fittings on the front arnt leaking, just bleeding a ton of air after i pump the brake lever and open the bleed valve. Im closing the bleed valve right as the brake lever bottoms out- what am I doing wrong here? Already went through 1 bottle of brake fluid. Im starting to get some tension in the front brake lever, but my skin is almost melting off from this brake fluid.
All fittings are torqued correctly, washers in correct places. I can say the both bolts to the clutch system were extremely tight, but all is working well with the cluthc and rear...just the front is slaying me. Help!
