busabrother
Which brake pads to get and who sells the cheapest SS Brake lines. I assume i only need one front line and one rear. I hear EBC HH's are the best for the busa. All opinion welcome. Thanks in advance
just simple math here bro....but yer about to cut yer braking force in half . That sit ok with you ?Which brake pads to get and who sells the cheapest SS Brake lines. I assume i only need one front line and one rear. I hear EBC HH's are the best for the busa. All opinion welcome. Thanks in advance
atta boy....Maybe i'll just stick with switching to stainless steel lines and keeping both rotors becasue I generally use only my front brakes. I need all I can get. Because I don't pose. I RIDE BABY
All ya dotta do is replace it, if ya don't like it.I likey. I might try it.
Trail braking is continuing to use the brakes after you have entered a corner/turn. The ideal is that all braking is done before the bike begins to turn, thus all of the tire traction can be used for cornering grip, and not lost to braking. When you stay on the brakes through the turn, not completing braking before the turn is initiated, that is trail braking - and can be done with either brake, though is probably a lot safer with the rear. Applying the brakes mid corner is not trail braking either - it is only the CONTINUED braking into a corner that is trail braking.the backs are great for settling her down(trail brakin')
