gabelbrucken
Here's my new steering damper
Nice. Did you take the stock on off? Just asking.
Yea that looks pretty sweet. Im curious as well if you took the stock one off, also what made you go with that damper as opposed to the scott ohlins or the gpr's? What did that one cost you?
what kind of oil do you use for changin stock damper's oil? regular motot oil, brake fluid, what?
Posted via Mobile Device
I found them at IndySuperBike for $420... curious how the linear dampers stack up against the rotary(?) style units.. either way, is a nice add-onYea that looks pretty sweet. Im curious as well if you took the stock one off, also what made you go with that damper as opposed to the scott ohlins or the gpr's? What did that one cost you?
