How to adjust Talon alarm settings
kevin567
Looking for some help setting up a Talon T-2200 alarm that came with my 07 Busa. I searched around for an owner's manual for the alarm but was unable to find anything. The company seems to be out of business and for once Google was rather unhelpful.
I found the system reset sequence (turn ignition key on/off x12 within 10 seconds, press any key on the remote) so now it's working, but much too sensitive. I just tap the pillion and it goes off. I understand there are several settings, and maybe even a warn-before-alarm setting.
Any help would be greatly appreciated!!
Canadian brand/manufacturer, right? Do you have an audio/video installer near you? They might be your best bet. Best of luck.
P.S. Below review is the best I could find about the T-2200:
Motorcycle Alarm - webBikeWorld
Thanks... I even tried Wayback.com (one of the coolest sites ever!) and there is no archive of the manual. I'll call some local shops and see if they have any memory of this alarm. Seems to be around 6 years old.
Turn key switch On
press and Hold * for 2 seconds
system will enter sensitivity mode
press lock button to increase sensitivity
press unlock button to decrease sensitivity
5 levels are available. factory is level 3
the # of chirps is the level your on..
Awesome, thanks for the info.
What about other settings like chirp on/off, alarm auto-enable on/off, etc?
