So I've been working on a trike for a while. It's got a gen I busa motor with a turbo. I built the whole thing and got it running with nothing but the search function . But I need a little help. I'm just about ready to take it for run but really need some help making sure I got the clutch set up. So how would you guys test it out. So far I've got a stop on the pedal that limits the travel of the slave push rod. The rod was shiny and clean where it travels in and out of the motor, and filthy every where else. So I pushed the clutch until all the clean part of the rod traveled in the motor and set my pedal stop there. I thought this would do it, but it's pretty hard to shift into 1st. Also I jacked up the rear wheel, started in first, let the wheel spin. Pushed the clutch thinking the wheel would stop if it was set up right, but it just spins with the clutch in and out. So I dunno? I've got plenty of more room for slave travel, but I really don't want to bust the slave cylinder. How would you guys set this up?
[/URL][/IMG]
