jphilipson
Working on a wiring harness for my new aux lights, and it will be running a relay. The fuse and relay will be mounted under the tank. Can anyone recommend a good wire that is only hot on ignition to tap into to trigger the relay in this area?
After that the current will hit the controller for the LED lights that will allow me to dim/adjust as well as switch on/off remotely. Controller also has a high bean trigger for full power - will be pretty sweet once it's hooked up.
