I have been having problems starting the engine when it gets hot for over a year now. The engine seems to kick back on the starter when I attempt to restart the bike say 20 minutes after a ride. If I turn the key on and wait maybe 10 sec before hitting the start button, the problem seems much worse. I now try to hit the starter buttonas soon as the Tach/speedo gauges settle.
I added a "homemade" switchable TRE maybe a year ago. I am not sure if it is the problem due to changing the timing. I rarely check to see what position the TRE switch is in. Usually I can tell it is on if the bike throttle response is "twitchy" during low speed parking lot maneuvering.
