Kaptain Kanji
When I got my Busa, I found amongst other surprises that the turn signal mechanism didn't
work smoothly and the horn didn't work at all. After doing a quick electrical check which pointed to the horn trouble
being in the switch housing, I took my can of silicon spray
with the little red tube and sprayed a goodly amount inside the turn signal/horn housing
on the left handlebar. This cleared up both problems and everything works fine now.!!
I also use the silicon spray to preserve rubber grommets, boots, hoses and plug wires.
Great stuff..!!
Great stuff..!!
