Honda abs vs Hayabusa abs
Kiwi Rider
Great comparo Bryan, with the Hondas being as good as they are in the lever feel, no braided hoses required, would you agree?
Now I understand why the ABS removal is so common.
Thanks for the info there mate!
sixpack577
Top Gun
....who has the adjuster on level 1 anyways? 3 or 4 is standard...or am I wrong?
I like having both levers adjusted so far out that I can pull them in(with 1 or 2 fingers), and not touch or crush my other 2-3 fingers holding the grips.
With minimal lever travel.
If mc's or cable clutch can't do that within normal lever adjustment, I don't wanna ride it.
Just my 2 cents, if it's worth that.
Kiwi Rider
Wait, Suzuki abs is bad because of a lever travel adjustment?
I think what he means is that the lever is able to come all the way to the bars because of the 'squishy' or soft feel (usually caused by rubber brake hose expansion) no matter where the lever position is set to.
This was explained to me by a very well trained factory Suzuki tech like this . . . "The reason why the lever travel is 'excessive'. . . .
(speaking of the amount of travel BEFORE the brake starts to work, NOT the 'squishy feel' issue, as explained previously, usually caused by rubber hose expansion or the compression of any air in the system) ) . . . . on the Busa master cylinders compared to say a Brembo m/cyl, is because the Suzuki m/cyl has a larger diameter scavenge port (the hole that goes between the bore and the reservoir) and hence the piston has more travel to slide across that hole to block it, until the fluid begins to really move and push on the caliper pistons.
Also, the 12 caliper pistons have a large surface area compared to the usual 8, to push on so this also exacerbates the problem.
The Brembo's scavenge port is smaller in diameter and the piston has less travel to block off the port and start to move the fluid to push the 8 pistons usually found in Brembo calipers.
Also the m/cyl diameter to caliper piston surface area ratio comes into play as well, if you want more power in the 'push' of the fluid, you need to decrease the m/cyl diameter OR increase the caliper piston surface area.
So the issue is inherent in the design of the m/cyl itself.
I intend to find a good radial m/cyl and fit it to my Gen 1 and hopefully get a better brake feel.
c10
My 2018 suzuki with the brembo calipers does not do that
Just saying
You are either very lucky or something is wrong ;) every one on the show room for the last few years I test do it . Today I even tried the DL1000 models , and a DL650 with same result . It was the first time I thought to video it , and compare to another brand on the show room floor
WuzzaCBXRider
In re: “I think what he means is that the lever is able to come all the way to the bars because of the 'squishy' or soft feel (usually caused by rubber brake hose expansion) no matter where the lever position is set to.”
But the video shows only the lever travel in the number one position.
I think I’ve mentioned before that the huge Brembos on my Caddy feel mushy compared to the huge Corvette branded brakes on my Vette, both with ABS. Nevertheless, both brakes work very well. Once again the HH pads coupled with braided SS lines on my 06 allow the brakes to work extremely well, extremely well, with good modulation too.
Hauie
I don't mind the ABS on my 2018 hayabusa, but it does feel a little squishier than the ninja. They both work well though (I think the hayabusa brakes are smoother).
c10
With lever in the #1 position it is furthest away from the grip , and it came to the grip when squeezed with minimal effort . Everything was upgraded on my bike . Rotors , Pads , Fluids , Master cylinder , lever and all had the same result as 1st video above just it did stop sooner with better pads/rotors/fluids .
By simply changing lines ( deleted ABS to do so ) the last video shows the lever travel difference . I use to run the ASV lever way OUT to keep it from going to the grip . Now the lever is at a better resting spot , feel , and modulation have been improved 10 times over before .
Maybe I'm asking too much to have a MSRP 15,000 USD bike with decent brakes .
Johnnie Phatt
No I don't think so. Anything this fast should almost stand on its nose with stopping power. Now like most people I do not ride with the lever in the number 1position. But I have had one close call and I can only say I'm very happy with the brakes on mine abs and all. Perhaps I'm not as fast as I think I am ;)
Thread starter Similar threads Forum Replies Date
UncleSteve Honda ABS Brake by wire General Bike Related Topics 5
J Craigslist Find (Honda) General Bike Related Topics 9
bigoltool Bought a Yamaha, and a Honda yesterday! Random Thoughts 1
sixpack577 1975 Honda CB550 General Bike Related Topics 16
sixpack577 2019 Honda CRF450L Dual Sport General Bike Related Topics 21
Johnnie Phatt Honda 250 6 Cylinder Off Topic 2
WuzzaCBXRider Honda Hurricane anyone? General Bike Related Topics 27
AJAY Honda T360 truck Off Topic 5
Kiwi Rider 99 'Busa vs '12 Repsol Honda CBR1000RR...sheesh! The Playground 12
Jose J Ortega Honda Type 2 Coolant Maintenance and Do-It-Yourself 4
fallenarch Honda RC213 V4 S, Really? Random Thoughts 7
bigoltool Honda Project 2&4 Concept. General Bike Related Topics 2
Twobrothersbusa Rebuild Thread...It's a Honda General Bike Related Topics 6
M Eric C with Honda East of Toledo Random Thoughts 3
R What happened to Honda East?? General Bike Related Topics 14
M 2003 Busa Powered Honda Beat Busa Mods 8
captain Honda East Toledo leaving the site.... General Bike Related Topics 14
B Anyone have a theory on how Honda and Marquez won't win this weekend? General Bike Related Topics 12
Fireman6615 Honda East General Bike Related Topics 16
T Wierd Bike - 2014 HONDA NM4 Vultus General Bike Related Topics 7
black diamond busa our very own honda east justin grudge racing Random Thoughts 15
M Thoughts, feelings on the honda cb1000? Random Thoughts 11
Taylor Honda Grom Random Thoughts 23
Chango The old formula Honda plastic cleaner and waxing your bike... General Bike Related Topics 7
Pecan Pouch Thinking about getting a Honda. Random Thoughts 6
GsxrBots You meet the nicest people on a Honda... Random Thoughts 15
rubbersidedown Honda car tech in the house? Random Thoughts 7
B Honda's machines are so good - it sucks! General Bike Related Topics 8
Fireman6615 Honda East Random Thoughts 4
GsxrBots Justin from Honda East.... Bad news.... Random Thoughts 24
Twobrothersbusa New Honda CB1100 General Bike Related Topics 35
mikey28804 Justin at Honda East does it again General Bike Related Topics 5
Cjbowler 03 Honda 600rr redbull bike General Bike Related Topics 36
mikey28804 Justin At HondA East General Bike Related Topics 8
Superzuki Testimonial for Justin at Honda East General Bike Related Topics 6
OneTrueRider New Honda Model ??? General Bike Related Topics 20
D From a: Honda CBX1000 in line six to GSXR1000 to a 1500 Boulevard back to a Hayabusa New Owners Forum 14
M 1st GEN IN HONDA BEAT CAR Busa Mods 1
skydivr Honda Easts reputation grows Random Thoughts 13
GsxrBots You meet the nicest people on a Honda? Random Thoughts 28
The Big Red One Justin from Honda East comes through for another member :-) General Bike Related Topics 9
Runner44 Craigs List Find-1981 Honda CBX 1.5 Miles-One of Three General Bike Related Topics 14
Lurch Justin from Honda East comes through again Random Thoughts 27
Bubba Zanetti Honda 50 racing Videos 4
Flicka Unreal Control On Honda CBR600RR Videos 28
GsxrBots Happy Birthday Honda East Justin! Random Thoughts 19
Blanca BusaLess Santa from Honda East passed by yesterday.... Random Thoughts 13
EarlyBird HONDA EAST (JUSTIN) Thank You! General Bike Related Topics 14
labrocha Honda East Justin (The Man) Random Thoughts 10
kennym4 Justin (Honda East) General Bike Related Topics 23
Similar threads
Latest Bikes
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
  • My 2014 Hayabusa
    • Dljat2
    • Updated:
  • Hi Everyone
    Loved
    • BirolBora
    • Updated:
Forum statistics
Threads
174,202
Members
48,300
Latest member
NorthernViking
