I needed a ramp for Busabash, I have a small Tacoma Pickup, it doesn't have a lot of extra room once the bike is loaded. I spent a lot of time looking online and could not find a ramp that met all my needs.
I decided to make my own ramp out of (3) 2"x12"x8' planks. Weight is concentrated on the center plank, so it would need to be reinforced, also traction is critical there.Center Section has an aluminum box for added strength, I got this box from an old ramp, a friend gave to me years ago.
At first I thought of hinging the three planks, but it made more sense to leave them separate (for storage flexibility). I ratchet tie them together when in use.
The steel top ramp brackets (Northern Tool) are rated at 750lbs, so I doubled them on the center plank. The Ultra Anti Slip grate, I got from McMaster-Carr, it was $109.00 and a additional $68.00 to truck, since it was too big for U.P.S.
I used my laminate trimmer (small router) to cut some ¼"deep traction grooves in the outside ramp. Sealed the wood with Olympic maximum waterproofing sealant (Lowes, 24.00/gal.)
Total cost was a little over $300.00, I think it will work well.
