The Fletch
i have the hmf highmount system and the left side rubbed a hole in my swing arm the upper part what should i do about this? contact hmf and #####? do i need a new swingarm? is it safe to ride on? i'll try to post a pic
Cool Paul ... thanks for the advice!!Shim the pipe out,take the swingarm off and go have it heliarc welded up,just tell the welder to turn his machine waaay down, the aluminum is thin,after you get it welded up,grind it down sand it,then either polish or chrome it.I've done this,no problems.NJ.::
You know I gotcha DJ! How's the #2 boosted project coming along?Cool Paul ... thanks for the advice!!Shim the pipe out,take the swingarm off and go have it heliarc welded up,just tell the welder to turn his machine waaay down, the aluminum is thin,after you get it welded up,grind it down sand it,then either polish or chrome it.I've done this,no problems.NJ.::
Picking it up next Monday ... I'll post pics, charts, and ride reportYou know I gotcha DJ! How's the #2 boosted project coming along?Cool Paul ... thanks for the advice!!Shim the pipe out,take the swingarm off and go have it heliarc welded up,just tell the welder to turn his machine waaay down, the aluminum is thin,after you get it welded up,grind it down sand it,then either polish or chrome it.I've done this,no problems.NJ.::
Good point Paul ... I don't know how I missed mine as I thought I was washing and inspecting my scoot good enough ... but obviously not ... it is kind of hidden behind the pipe and I missed it ... actually GPW found mine the other day. Lesson learned though ... I have to be more diligent!!You know, a rub hole like that doesn't happen overnight. Your just now voicing concern? Seems that you might want to inspect the rest of your bike also.
I mean what's so freakin' hard about making an exhaust to spec w/out having to adjust 10 diff. things through trial and error to get it to fit. It's not like HMF can't get their hands on an OE Busa.I was going to get this same system,then someone here told me it fits like S hit...so now this thread makes me more of a believer.
I am now looking into a Ti-Force....
I am with you on this, i mean yeah the hmf system looks and sounds bad a$$, but man i just keep hearing horror stories about them or the install of them. I don't knowWTF? Excuse me fellas, I don't have the HMF high mounts but it's on the wishful thinking list. If someone is going to shell out ~$1000.00+ for an exhaust system this crap "should not" be happening. HMF needs to get their rulers back out and re-measure if this is going to be the result.
This is making me think about going in another direction for an exhaust. Has HMF given any kind of response to this?
