JW OLDBUSA
Does anyone know of a higher output charging system that'll work on a '00 Busa. I measured mine at 28 amps at 14 volts max output. It also seems that the higher rpms the lower the voltage to about 12 volts. Are there any newer years that are higher or any mods to do on the stater rotor or reg??
My 3 wires going to the regulator burned at a connector. I replaced them with 12 ga. with soldered connectors to regulator. That works great now, but with extra bulbs in turnsignals and brake lights, and other acessories it'd be nice to have 10-15 more amps.
My lights flicker at idle with the engine rpm at night. I always keep my battery on a battery tender.
