High Mount HMF Single system.>
c50bartsBusa
Has anyone out there had problems installing a high mount HMF on their busa. I'm having a problem with the Y pipe under the back section of the bike. Where the small plastic is. 2 bolt hold the front plastics secure and the back 2 bolts hold the back section to the frame. This section is right on top of the pipe and it's definitly going to melt. Any Help out there?
hmm thought i posted to this once hmm musta not went through
yeah i run it and well mine melted i was lazy and didn't do anything what i shoulda done was this
Wrape the pipe with header wrap, then apply some heat sheilding to the belly pan you can also try using some washers to space it away
hope that helps
