high idle issue
3gturbo
idle fine when I started and ride until 5 mins into riding.....after I boost a few times and let the throttle off the idle goes way up to the rev limiter and does stop so I ended up cutting it off in the middle of riding and pull off to the side..turn it back on and started it back up... it's goin crazy again idles to the rev limiter...if I wait for 5 mins it goes back to normal....I don't see no sign of vaccum leak.. help..thanxs....
Is it possible that you have the throttle cable restricted???
you couldn't create a big enough vacuum leak to make it bounce off the rev limiter....wouldn't have enough fuel to do it anyway.
I'm with stunnah, something is wrong with your cables/throttle bodies causing it to hang. I don't see what else it could be. Bent butterflies would be consistant, not sparatic.....it wouldn't idle well either. Same with a vacuum leak.
I agree with Unc and Stunnah.  Lewt us know when you check out the cables.
have you put new grips on??
Do you runa a throttle lock of any kind, even when off can be a problem??
Have you adjusted your throttle at all??
Do you have anything near the throttle cables near the engine side??
<!--EDIT|Ninja Eater
Reason for Edit: None given...|1102869238 -->
