I installed my undertail and saved the friggin' rivets like the directions said, right? But they are not wanting to be reused. The undertail lined up beautifully, but the rivets won't hold, pop out, et cetera...what did you guys do? Any help?
Thanks!
J
Ok dude, heres what I did and suggest you doing as well. Take you butt down to Lowes and get a couple of expandable nuts and matching bolts to replace those cheezy azz rivets. You will need to widen the holes on the undertail just a little with a drill to get them to fit. Make sure its a snugg fit and not sloppy like your drawz (underwear).
Or you can go to the dealership and pay a arm and leg for them, there the same as the expandable nuts used on the windscreen, but cheaper.
My .02
